21615 Discussions
Ignored create_clock warning in C V design
Seadog
I have a Cyclone V design with a DDR 3 controller.  The reference clock for the DDR3 EMIF core is routed directly from a clock pin.  The .sdc file for the project has a create_clock command for that reference clock; the .sdc file for the EMIF core also has a create_clock command for the same clock (referenced as pll_ref_clk per the port name on the EMIF top level).
Quartus is giving me the following warning:
Warning (332049): Ignored create_clock at ddr3_v20_p0.sdc(264): Incorrect assignment for clock. Source node: clkinbot_p already has a clock(s) assigned to it. Use the -add option to assign multiple clocks to this node. Clock was not created or updated.
Should I:
  • comment out the create_clock command in the project .sdc file
  • use the -add option (not sure why I would; the clock is routed to only one place)
  • ignore the warning
sstrell
You can either ignore the warning or remove your create_clock command since, as you say, the clock is not being used anywhere else in your design.  Does the tool still show the design as fully constrained?
Seadog
The design is fully constrained, other than the parts I purposely did not constrain (it's on an eval board with a bunch of I/Os not really being used).  And certainly the EMIF core is constrained.
AdzimZM_Intel
Sorry for the delay in this topic.
You can either comment out the create_clock command in the project .sdc file or ignore the warning as has been mentioned by sstrell.
Do you have any further question?
Adzim
Seadog
No further info needed, thanks.
AdzimZM_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
