21611 Discussions
Import the OpenCV (image proccessing) C/C++ library in NiosII
Hello
I will make a image proccessing project, camera tracking.
Can I import the OpenCV library in NiosII?
- http://opencv.willowgarage.com/wiki/fullopencvwiki
- http://opencv.willowgarage.com/wiki/eclipse
Thank you
Antonio
You could start by compiling the cxcore and cv libraries, discard the highgui library. It's required a very careful modification of Makefiles. I guess it'll be easier if your system is uCLinux based, and maybe Makefiles modification is not required, check CV install guide.
hello,
please i want to know if i can import the library opencv_b4a with nios2 or powerpc or stratix3.
i have an FPGA board.
thanks an advance.
Hello Antonio,
I am currently working on benchmarking opencv on NIOS II. I was wondering if you had any luck with porting it to NIOS. If so would you be able to share code or point me in the right direction.
hi,
you find here an attachment file( in chinese ) perhaps it can help you.
translate it.
the most important page is from : 9-->12
this project use powerpc not NIOS2.
good luck
hello Antonioa et Aydi
are you succeed in import opencv Library in NiosII or powerpc??? please if you succeed on help me
thanks
i didn't compile opencv library but i compiled CImg.h library.
so you can try using CImg.h it's also good.
but if you want opencv you can try to compile it.
good luck
