21615 Discussions
In the Master Read Burst, how to recover from errors
In the Master Read Burst, if waitrequest signal has been effective, then how can I terminate the transmission, thank you
I'm not sure I understand your question. When the waitrequest signal is asserted, the transfer is paused. When it is deasserted, it continues, until the end of the burst operation.
I apologize for my ambiguous expression,I mean the master how to terminate the ongoing read burst
You can't. Once you start a burst operation, you need to complete it.
--- Quote Start ---
When a master starts a burst with an address of <a> and a burstcount value of <b>,
it is committing to <b> consecutive transfers starting at address <a>. The burst does
not complete until the master transfers <b> units of data. A master cannot abort the
burst without first exhausting remaining transfers in the current burst. The master can
issue a new read burst before the data for the previous burst has been returned.
--- Quote End ---
(Avalon spec)
