Programmable Devices
21615 Discussions
Information on how to interface with RAM stick included with Stratix III DSP Devel
I had posted previously on how to get my design in DSP Builder to work in Quartus II with SignalTap II Logic showing 128k output instead of 8k. I finally found a way to get the design compiled in 16k instead of 8k, however I noticed that it if I attempt to compile it at 32, 64, and 128k, the design will not compile due to a shortage of memory. The FPGA board is the Stratix III DSP Development Kit. It comes with an add-on board of 1GB of RAM. Putting this on the board should get it to compile up to 128k, but after putting it on, it hasn't worked. I'm guessing the board has not recognized it or can't interface to it. Does anyone know how to verify that the board is seeing the RAM add-on and if it's not seeing it, how to interface to it?
Daniel
SignalTap can only use the FPGA's on-chip memory and won't use an external RAM chip. But why do you need to read so many output samples with signaltap?
