21611 Discussions
Inout port became output
Gianfranco9635
Hi guys,
i'm trying to create a project based on a Bridge SPI to Avalon.  In my top entity i have a signal that is defined as "INOUT"  and that represent the I/O of my fpga (name signal is LSASBUS). My problem regards the eda netlist writer that create the file .vo. If i change something in my top entity and i compile the project, all work good. if i re-compile it, my project doesn't work. This happen because in the .vo file, the "INOUT" port became "Output" and i don't know why.  I'm using quartus lite versione 20.1.
How can i resolve? i include my top level file in vhdl.
FPGA_USER.vhd
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library lpm;
use lpm.lpm_components.all;
library altera_mf;
use altera_mf.altera_mf_components.all;
entity user is
port
-- Main clock inputs
mainClk : in std_logic;
slowClk : in std_logic;
-- Main reset input
reset : in std_logic;
-- MCU interface (UART, I2C)
mcuUartTx : in std_logic;
mcuUartRx : out std_logic;
mcuI2cScl : in std_logic;
mcuI2cSda : inout std_logic;
-- Logic state analyzer/stimulator
lsasBus : inout std_logic_vector( 31 downto 0 );
-- Dip switches
switches : in std_logic_vector( 7 downto 0 );
-- LEDs
leds : out std_logic_vector( 3 downto 0 );
   state_out    : out std_logic_vector(4 downto 0)
end user;
architecture behavioural of user is
signal clk: std_logic;
signal pllLock: std_logic;
signal lsasBusIn: std_logic_vector( 31 downto 0 );
signal lsasBusOut: std_logic_vector( 31 downto 0 );
signal lsasBusEn: std_logic_vector( 31 downto 0 ) := ( others => '0' );
signal mcuI2cDIn: std_logic;
signal mcuI2CDOut: std_logic;
signal mcuI2cEn: std_logic := '0';
signal state :  std_logic_vector(4 downto 0);
component myAltPll
PORT
areset : IN STD_LOGIC  := '0';
inclk0 : IN STD_LOGIC  := '0';
c0 : OUT STD_LOGIC ;
locked : OUT STD_LOGIC
end component;
component SPI_Avalon_System
   PORT
    clk_clk       : in  std_logic; --   clk.clk
   reset_reset_n : in  std_logic; -- reset.reset_n
   spi_mosi      : in  std_logic; --   spi.mosi
   spi_ss        : in  std_logic; --      .ss
   spi_miso      : out std_logic;        --      .miso
   spi_sclk      : in  std_logic;  --      .sclk
         en_miso       : out std_logic;
      state         : out std_logic_vector(4 downto 0);
   ss_sys        : out std_logic
   end component;
begin
--* Main clock PLL
myAltPll_inst : myAltPll PORT MAP (
areset => reset,
inclk0 => mainClk,
c0 => clk,
locked => pllLock
--* LEDs
leds <= switches( 3 downto 0 );
--* lsasBus : inout std_logic_vector( 31 downto 0 )
lsasBusIn <= lsasBus;
lsasBus_tristate:
process( lsasBusEn, lsasBusOut, lsasBusIn ) is
begin
for index in 0 to 31 loop
if lsasBusEn( index ) = '1'  then
lsasBus( index ) <= lsasBusOut ( index );
else
lsasBus( index ) <= 'Z';
end if;
end loop;
end process;
system : SPI_Avalon_System
   port map(
      clk_clk        => mainClk,
   reset_reset_n  => reset,
   spi_mosi       => lsasBusIn(15),
   spi_sclk       => lsasBusIn(13),
   spi_ss         => lsasBusIn(12),
   spi_miso       => lsasBusOut(14),
      en_miso        => lsasBusEn(14),
state          => state,
ss_sys => lsasBusOut(5)
lsasBusOut(4 downto 0) <= state(4 downto 0);
lsasBusEn(5 downto 0) <= (others => '1');
lsasBusOut(8)<=lsasBusIn(13);
lsasBusEn(8)<= '1';
state_out <= state;
end behavioural;
FPGA-USER.vo --- FIRST COMPILATION
`timescale 1 ps/ 1 ps
module user (
          mainClk,
          slowClk,
          reset,
          mcuUartTx,
          mcuUartRx,
          mcuI2cScl,
          mcuI2cSda,
          lsasBus,
          switches,
          leds,
          state_out);
input mainClk;
input slowClk;
input reset;
input mcuUartTx;
output mcuUartRx;
input mcuI2cScl;
inout mcuI2cSda;
inout [31:0] lsasBus;
input [7:0] switches;
output [3:0] leds;
output [4:0] state_out;
FPGA-USER.vo ----SECOND COMPILATION
module user (
          mainClk,
          slowClk,
          reset,
          mcuUartTx,
          mcuUartRx,
          mcuI2cScl,
          mcuI2cSda,
          lsasBus,
          switches,
          leds,
          state_out);
input mainClk;
input slowClk;
input reset;
input mcuUartTx;
output mcuUartRx;
input mcuI2cScl;
output mcuI2cSda;
output [31:0] lsasBus;
output [3:0] leds;
ShengN_Intel
Check this KDB https://www.intel.com/content/www/us/en/support/programmable/articles/000086339.html, this is known previous problem and had been concluded using the workaround clean the project before running compilation to resolve the problem. Based on previous internal team reply: There is no capacity or further step taken for this.
The problem only exists in linux version but not in window version.
Sheng
FvM
just a guess, you see inout port implemented as output only because tri-state output is always enabled in your code. If so, you'd see respective synthesis warnings.
Gianfranco9635
The tri-state outputs are not always active. In fact my lsasBusEn is initialize to 0.
Maybe I’m wrong. How would you fix my code?
Thank you!!
ShengN_Intel
Sheng
Gianfranco9635
I’m using quartus lite 20.1 in Windows.
if I use clean project under project tab, it works good. But if I want to clean it automatically every time that I want to compile, what I should do? Create a script and add it on project?
thanks
ShengN_Intel
Yes, you can create a tcl script for example like test.tcl. Then add the command below to the tcl script:
quartus_sh --clean test
quartus_sh --flow compile test
And then source the tcl script to clean and compile
[Edited] If for quartus_sh --clean test, project name test can't be used then use with the .qpf one like test.qpf
ShengN_Intel
Or you may also create tcl script like below and run with quartus_sh -t:
package require ::quartus::project
package require ::quartus::flow
project_open -revision test test
project_clean
execute_flow -compile
