21602 Discussions
Install QuartusII 10.1 to Ubuntu 10.04 error!
Hi :
When I install QuartusII 10.1 on Ubuntu 10.04,
I find those error message.
Can you help me!
thansk..............
joe@joe-ubuntu-10:~$ bash ./10.1_quartus_free_linux.sh
log :
:command not find us_free_linux.sh: line 3:
:command not find us_free_linux.sh: line 9:
:command not find us_free_linux.sh: line 16:
./10.1_quartus_free_linux.sh: line 20: syntax error near unexpected token `elif'
'/10.1_quartus_free_linux.sh: line 20: `elif test -x /usr/ucb/echo; then
absolutely yes
Try the following:
sudo rm /bin/sh
sudo ln -s /bin/bash /bin/sh
<install the software>
Works for me.
Ben
There is a same problem I met, is there other meathod? Thanks a lot!
i installed it, but i dont know how to run, does any one have a idea?
I already fix it.
Because I download 10.1_quartus_linux.sh by windows system, it have ^M issue.
So I download in Ubuntu 10.04 platform by => sudo wget ftp:\\ftp.altera.com\outgoing\release\10.1_quartus_linux.sh
Then => sudo sh 10.1_quartus_linux.sh
--- Quote Start ---
--- Quote End ---
1. sudo gedit /etc/profile
2. Add this setting in the file end.
SOPC_KIT_NIOS2=/home/XXX/altera/10.1/nios2eds
SOPC_BUILDER_PATH=/home/XXX/altera/10.1/nios2eds
QUARTUS_ROOTDIR=/home/XXX/altera/10.1/quartus PATH=$PATH:/home/XXX/altera/10.1/quartus/bin:/home/XXX/altera/10.1/nios2eds/bin:/home/XXX/altera/10.1/quartus/linux
PATH=$PATH:/home/XXX/altera/10.1/modelsim_ae/linuxaloem:/home/XXX/altera/10.1/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin
LD_LIBRARY_PATH=/lib:/usr/lib:/home/XXX/altera/10.1/linux
unset GCC_EXEC_PREFIX
export LM_LICENSE_FILE QUARTUS_ROOTDIR SOPC_KIT_NIOS2 SOPC_BUILDER_PATH
export PATH LD_LIBRARY_PATH QUARTUS_64BIT
/* XXX is your name */
3. reboot your system
4. Type quartus in command line.
