I really like the idea of instantiating a module without a component part and then in main code using entity work. :HA2 : entity work.halfadder port map (s1,cin,sum,c2);
The idea came from this link: http://vhdlguru.blogspot.com/2010/03/entity-instantiation-easy-way-of-port.html It works fine for my VHDL modules, but when i have some AHDL modules in my design and i want to instantiate them the same way, Quartus II gives me an error: --- Quote Start --- Error (10481): VHDL Use Clause error at main.vhd(155): design library "work" does not contain primary unit "ahdl_module" --- Quote End --- Is there a way to work it around and not to use components when instantiating ahdl modules ? Perhaps quartus puts ahdl modules into some different library, or adds some name in the entity of that module - i wasn't able to find it. best regards madness
Nope. For mixed language you need to use components, because the VHDL compiler has no knowledge of the AHDL, hence you need it to be a black box - which is what components are for.
thanks for the reply :) i won't be trying to do that. best regards madness
