21615 Discussions
Intel FAE: Which of the 3 programming pods (Intel FPGA Dowload Cable, Intel Download Cable II and Ethernet Blaster Download Cable) support the new EPCQ-A configuration devices?
TJohn
Abe
Valued Contributor II
Taken from the EPCQ-A data sheet:
* ISP support with Intel FPGA Download Cable II, Intel FPGA Download Cable, or
Intel FPGA Ethernet Cable
*Reprogrammable memory more than 100,000 program-erase cycles
• Write protection support for memory sectors using status register bits
• Fast read, extended dual input fast read, and extended quad input fast read of the
entire memory using a single operation code
• Reprogrammable with an external microprocessor using the SRunner software
driver
• In-system programming (ISP) support with the SRunner software driver
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cfg/cfg_cf52014.pdf
