If I generate a clock within a MAXII pld, I can output that signal to a pin, wire the pin to a spare global clock input and use it without problem.
How do I do this connection internally without having to add a wire. How do I connect an internal node to a global clock line? (I'm trying to do this in VHDL).Link Copied
I don't understand your post. The Quartus fitter selects MAX II global clock signals automatically for respective signals, e.g. if you create a ripple clock, you can check in the fitter report resource section.
