21608 Discussions
Terasic Byteblaster
Hello
I am using a Terasic USB Byteblaster. I see that the Pin# 1 (DCLK - DCLK) and Pin# 9 (ASDO -> ASDI) of the Byteblaster are shorted. Should they be shorted by default or would they have been shorted during the development process ? I did not see my current increase when I was bringing up the board / trying to program the Cyclone III (EQFP package) or did not hear a pop or anything suspicious that could have shorted the two pins.
I found that out when I was checking the connections to ensure that I had the connections for the AS mode correctly done. I saw the short when the ByteBlaster was connected on the board and it was gone after I removed the Byteblaster. Thats how I found out about the short.
I am programming in AS Mode and Quartus II says "Can't recognize silicon id for Device 1"
Any help will be appreciated.
Ajay
Fixed ... It was the cable
1,3,5,7,9 was swapped with 2,4,6,8,10
Ajay
