21615 Discussions
Interrupt Sender component
I have made a custom component in SOPC builder. My component has a interrupt sender type signal (irq). When Im trying to build it I get these errors:
error:interrupt_sender associated addressable point out of range
error:interrupt_sender interrupt not associated with addressable connection point.
what's wrong?
Check your component *_hw.tcl file
You should have something similar to this for signal interrupt:
add_interface control_irq interrupt end
set_interface_property control_irq associatedAddressablePoint control_port
set_interface_property control_irq ASSOCIATED_CLOCK avalon_clock
set_interface_property control_irq ENABLED true
add_interface_port control_irq av_irq irq Output 1
Please note that this applies Quartus V9.0sp2.
Another version might use/generate different properties and/or additional tcl instructions
I studied much more and got the point that the cpu acknowledges the interrupt by reading an associated addressable point right? I have no such thing in my custom component hdl code. could it be the problem ?
what if I dont want my custom component to wait for an ack ?
anyway, how does cpu's ack to interrupts work? we dont have an avalon signal for ack.
tnx in advance
