21615 Discussions
Is a timer interval must be used with NIOS ?
RShal4
Is it that a timer interval MUST be used with NIOS ?
In nios ii software developer handbook, section 5.8.3 specifying thr default system timer, it is mentioned that on BSP generation it search for a timer.
But I see several tutrial in which no timer is used, so I am not sure if it is required or not.
ranran
AnandRaj_S_Intel
>>It's based on design requirements. for example we can use it when we want periodic interrupts.
>>The default script searches the .sopcinfo file for a timer component to use as the default system timer.Its's not default until you have timer is the Platform designer / QSYS system.
Anand
AnandRaj_S_Intel
Anand
