Programmable Devices
21616 Discussions
Is it a synthesizable verilog coding?
I delete it.
In that particular example it *should* be fine, because it is effectively equivalent to:
wire rst_n = !(B & C); always @ (posedge A or negedge rst_n) begin if(~rst_n) begin E <= 0; end else if (D) begin E <= F; end end
A is still used as the clock, and D is used as a clock enable.
--- Quote Start ---
--- Quote End ---
Thank you.
After post this, I try use Quartus "Technology Map Viewer", and it give me the answer.
Thank you anyway, you're very kind.
