21592 Discussions
Is it possible to edit the Reset Offset address of a .sof file without recompiling it?
ReubenS
Compilation of .sof files is pretty slow (~20 minutes) and I'll potentially be creating many with the only change being the Reset Offset.
sstrell
You don't mention what device you're targeting, but most likely no.  .sof is a binary programming file.  Any change like that (for Nios V?) would need the IP regenerated and recompiled.
