21594 Discussions
Is it possible to map a I/O port directly to a pad (not pin)?
REics
Is there a way (e.g. low-level primitive) where I can assign a particular pad directly to a I/O port, without having to use the pin name? Instead of
set_location_assignment PIN_A13 -to MY_IO
i would like to write something like
set_location_assignment PAD_35 -to MY_IO
Thanks!
REics
Ok, that was too fast. It works. But that leads me to another question: How can I force the fitter to accept unbonded pads?
AqidAyman_Intel
Did you get the fitter error when try to compile the design?
Aqid
AqidAyman_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
