I'v just received a Arria II GX FPGA Development Kit, and the delivered software and test software are all based on quartus II 9, which is the same as the altera online resource.
I got a quartus 10 sp1 on my computer but the test software seems not compatible with the new quartus version. Do I have to uninstall the quartus software and reinstall a ver 9 software?Link Copied
You can install as many versions as you want side by side. Each version installs in its own subdirectory e.g on my (windows) machine C:altera\90sp2\... and C:altera\91\...
--- Quote Start --- You can install as many versions as you want side by side. Each version installs in its own subdirectory e.g on my (windows) machine C:altera\90sp2\... and C:altera\91\... --- Quote End --- Do you mean the delivered software with the kit is not compatible with quartus10? I did ever tried installing ver 10 with ver 9.1 existing in my computer, but I failed before I uninstalled the ver 9.1.
I haven't installed 10.0 as I'm in the middle of a large project. But some time ago I had to do support for some legacy device and I went back through a lot of QII versions and was able to install each onel nicely alongside 9.1.
I think it is wise to install the Quartus II version that came with the kit. You will be able to compile all examples etc. Later on you can give 10.0 a try.- Mark as New
--- Quote Start --- I haven't installed 10.0 as I'm in the middle of a large project. But some time ago I had to do support for some legacy device and I went back through a lot of QII versions and was able to install each onel nicely alongside 9.1. I think it is wise to install the Quartus II version that came with the kit. You will be able to compile all examples etc. Later on you can give 10.0 a try. --- Quote End --- Thanks for reply, and I think your advice might be the best choice I could choose until now. I may try it a little bit later.
