- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi all,
I was used to simulate my project with the simulation tool in earlier version of quartus but now, this tool is no longer available with the version 10.0 and I have to use ModelSim. My questions are : Is there an easy way like "vector waveform file" to initiate the simulation or do I have to do all the stuff with command lines? Do you know a good tutorial to learn how to use ModelSim? Thank youLink kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The easiest way to do this is in a testbench. You can write the testbench in your favourite HDL language and create waveforms to your heart's content, using direct assignments, waveform functions or reading from files. The Testbench is not going to be synthesised, so you can do loads of stuff you normally cant do.
What language do you normally create designs in?- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Write a tesbench.
You've to set the Settings.. | simulation in order to compile the testbench. An example, combinatorial, testbench is the for a priority encoder following (remove line numbers): 1 `timescale 1ns/1ps // define simulation time units 2 module prenc83_tb(); // module with no inputs or outputs 3 reg [7:0] Atb; // reg net type. To be assigned in the initial block 4 wire [2:0] Ytb; 5 wire idle; 6 prenc83 d1(.A(Atb),.Y(Ytb)); // UUT named d1 7 initial // Just once at the beginning of the simulation 8 begin 9 Atb = 8'h01; // Eight bits hexadecimal value 10 # 100; // 100 time units delay -> 100 ns 11 Atb = 8'h02;# 100; 12 Atb = 8'h04;# 100; 13 Atb = 8'h08;# 100; 14 Atb = 8'h10;# 100; 15 Atb = 8'h20;# 100; 16 Atb = 8'h40;# 100; 17 Atb = 8'h80;# 100; 18 Atb = 8'h44;# 100; 19 Atb = 8'hF0;# 100; 20 Atb = 8'h00;# 100; 21 Atb = 8'hCF;# 100; 22 $stop; // System call that stops the simulation 23 end 24 endmodule For a sequential project you need a clock. It can be defined, in the testbench, as: // Generates the clock waveform parameter PERIOD=20; always begin CLKtb=0;# (PERIOD/2.0); // Delays by PERIOD/2 time units CLKtb=1;# (PERIOD/2.0); end- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
does Modelsim support Quartus's design entry files (bdf, bsf) or do I need to convert everything to VHDL\Verilog?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
You need to convert them.
The Quartus simulator never really supported them either - it only simulated a post place and route netlist.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- You need to convert them. The Quartus simulator never really supported them either - it only simulated a post place and route netlist. --- Quote End --- for me, as a simple user, it's the same thing. I guess that Modelsim does not support post fitter netlist? I really enjoy using graphic interface, and I don't think my company will purchase HDL designer...
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
if you still have 9.1sp2 or earlier installed you can create an HDL test bench from your .vwf
as mentioned you can also create an HDL file for the .bdf. your Megafunctions should all have a source file in an HDL. be sure to create them all in the same HDL, as both versions of ModelSim-Altera only support a single HDL. when you create an HDL file from a .bdf, the .bsf are bypassed and the the source HDL for the .bsf is instantiated directly i would also take a look at Altera's NativeLink feature that automates running ModelSim for you- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi all and thanks for your answers,
I've created a testbench file from a vwf file. Then I've added it to my project with quartus 10.0. Now when I click on "Run EDA Simulation tool -> EDA RTL Simulation", ModelSim is launched but all ouputs stay in UnknownSate. Any Idea?- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Can you post the testbench and the HDL for your design?
Probably the node names in testbench and HDL are not the same.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
right, and also post a list of how you have your NativeLink fields filled out
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I found my problem !
I had converted the BDF files into VHD files, but I haven't change them in "Assignment->Settings->Files", so the compilation continued to use the BDF files. Thank you all for your help. Just one more thing, there are a lot of stuff at the beginning of the Testbench file. Is that compulsary? My testbench file is in the 3 post below, the forum doesn't allow me to post messages above 10000 caracters...- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
-- First part of the testbench file --
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY STD;
USE STD.textio.ALL;
PACKAGE test_project_vhd_tb_types IS
-- input port types
-- output port names
CONSTANT output_test_name : STRING (1 TO 11) := "output_test";
CONSTANT sync_out_name : STRING (1 TO 8) := "sync_out";
-- n(outputs)
CONSTANT o_num : INTEGER := 2;
-- mismatches vector type
TYPE mmvec IS ARRAY (0 to (o_num - 1)) OF INTEGER;
-- exp o/ first change track vector type
TYPE trackvec IS ARRAY (1 to o_num) OF BIT;
-- sampler type
SUBTYPE sample_type IS STD_LOGIC;
-- utility functions
FUNCTION std_logic_to_char (a: STD_LOGIC) RETURN CHARACTER;
FUNCTION std_logic_vector_to_string (a: STD_LOGIC_VECTOR) RETURN STRING;
PROCEDURE write (l:INOUT LINE; value:IN STD_LOGIC; justified: IN SIDE:= RIGHT; field:IN WIDTH:=0);
PROCEDURE write (l:INOUT LINE; value:IN STD_LOGIC_VECTOR; justified: IN SIDE:= RIGHT; field:IN WIDTH:=0);
PROCEDURE throw_error(output_port_name: IN STRING; expected_value : IN STD_LOGIC; real_value : IN STD_LOGIC);
PROCEDURE throw_error(output_port_name: IN STRING; expected_value : IN STD_LOGIC_VECTOR; real_value : IN STD_LOGIC_VECTOR);
END test_project_vhd_tb_types;
PACKAGE BODY test_project_vhd_tb_types IS
RETURN CHARACTER IS
BEGIN
CASE a IS
WHEN 'U' =>
RETURN 'U';
WHEN 'X' =>
RETURN 'X';
WHEN '0' =>
RETURN '0';
WHEN '1' =>
RETURN '1';
WHEN 'Z' =>
RETURN 'Z';
WHEN 'W' =>
RETURN 'W';
WHEN 'L' =>
RETURN 'L';
WHEN 'H' =>
RETURN 'H';
WHEN '-' =>
RETURN 'D';
END CASE;
END;
RETURN STRING IS
VARIABLE result : STRING(1 TO a'LENGTH);
VARIABLE j : NATURAL := 1;
BEGIN
FOR i IN a'RANGE LOOP
result(j) := std_logic_to_char(a(i));
j := j + 1;
END LOOP;
RETURN result;
END;
PROCEDURE write (l:INOUT LINE; value:IN STD_LOGIC; justified: IN SIDE:=RIGHT; field:IN WIDTH:=0) IS
BEGIN
write(L,std_logic_to_char(VALUE),JUSTIFIED,field);
END;
PROCEDURE write (l:INOUT LINE; value:IN STD_LOGIC_VECTOR; justified: IN SIDE:= RIGHT; field:IN WIDTH:=0) IS
BEGIN
write(L,std_logic_vector_to_string(VALUE),JUSTIFIED,field);
END;
PROCEDURE throw_error(output_port_name: IN STRING; expected_value : IN STD_LOGIC; real_value : IN STD_LOGIC) IS
VARIABLE txt : LINE;
BEGIN
write(txt,string'("ERROR! Vector Mismatch for output port "));
write(txt,output_port_name);
write(txt,string'(" :: @time = "));
write(txt,NOW);
writeline(output,txt);
write(txt,string'(" Expected value = "));
write(txt,expected_value);
write(txt,string'(" Real value = "));
write(txt,real_value);
END;
PROCEDURE throw_error(output_port_name: IN STRING; expected_value : IN STD_LOGIC_VECTOR; real_value : IN STD_LOGIC_VECTOR) IS
BEGIN
write(txt,NOW);
END;
LIBRARY ieee;
USE WORK.test_project_vhd_tb_types.ALL;
ENTITY test_project_vhd_sample_tst IS
PORT (
master_clock : IN STD_LOGIC;
N : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
sync_in : IN STD_LOGIC;
sampler : OUT sample_type
END test_project_vhd_sample_tst;
ARCHITECTURE sample_arch OF test_project_vhd_sample_tst IS
SIGNAL tbo_int_sample_clk : sample_type := '-';
SIGNAL current_time : TIME := 0 ps;
BEGIN
t_prcs_sample : PROCESS ( master_clock , N , sync_in )
BEGIN
IF (NOW > 0 ps) THEN
IF (NOW > 0 ps) AND (NOW /= current_time) THEN
IF (tbo_int_sample_clk = '-') THEN
tbo_int_sample_clk <= '0';
ELSE
tbo_int_sample_clk <= NOT tbo_int_sample_clk ;
END IF;
END IF;
current_time <= NOW;
END IF;
END PROCESS t_prcs_sample;
sampler <= tbo_int_sample_clk;
END sample_arch;
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
-- First Part of the testbench file page2 --
LIBRARY ieee;
LIBRARY STD;
USE STD.textio.ALL;
ENTITY test_project_vhd_check_tst IS
GENERIC (
debug_tbench : BIT := '0'
PORT (
output_test : IN STD_LOGIC;
sync_out : IN STD_LOGIC;
sampler : IN sample_type
END test_project_vhd_check_tst;
ARCHITECTURE ovec_arch OF test_project_vhd_check_tst IS
SIGNAL output_test_expected,output_test_expected_prev,output_test_prev : STD_LOGIC;
SIGNAL sync_out_expected,sync_out_expected_prev,sync_out_prev : STD_LOGIC;
SIGNAL trigger : BIT := '0';
SIGNAL trigger_e : BIT := '0';
SIGNAL trigger_r : BIT := '0';
SIGNAL trigger_i : BIT := '0';
SIGNAL num_mismatches : mmvec := (OTHERS => 0);
BEGIN
-- Update history buffers expected /o
t_prcs_update_o_expected_hist : PROCESS (trigger)
BEGIN
output_test_expected_prev <= output_test_expected;
sync_out_expected_prev <= sync_out_expected;
END PROCESS t_prcs_update_o_expected_hist;
-- Update history buffers real /o
t_prcs_update_o_real_hist : PROCESS (trigger)
BEGIN
output_test_prev <= output_test;
sync_out_prev <= sync_out;
END PROCESS t_prcs_update_o_real_hist;
-- expected sync_out
t_prcs_sync_out: PROCESS
BEGIN
sync_out_expected <= 'X';
WAIT;
END PROCESS t_prcs_sync_out;
-- expected output_test
t_prcs_output_test: PROCESS
BEGIN
output_test_expected <= 'X';
WAIT;
END PROCESS t_prcs_output_test;
-- Set trigger on real/expected o/ pattern changes
t_prcs_trigger_e : PROCESS(output_test_expected,sync_out_expected)
BEGIN
trigger_e <= NOT trigger_e;
END PROCESS t_prcs_trigger_e;
t_prcs_trigger_r : PROCESS(output_test,sync_out)
BEGIN
trigger_r <= NOT trigger_r;
END PROCESS t_prcs_trigger_r;
t_prcs_selfcheck : PROCESS
VARIABLE i : INTEGER := 1;
VARIABLE last_output_test_exp : STD_LOGIC := 'U';
VARIABLE last_sync_out_exp : STD_LOGIC := 'U';
VARIABLE on_first_change : trackvec := "11";
BEGIN
WAIT UNTIL (sampler'LAST_VALUE = '1'OR sampler'LAST_VALUE = '0')
AND sampler'EVENT;
IF (debug_tbench = '1') THEN
write(txt,string'("Scanning pattern "));
write(txt,i);
write(txt,string'("| expected "));write(txt,output_test_name);write(txt,string'(" = "));write(txt,output_test_expected_prev);
write(txt,string'("| expected "));write(txt,sync_out_name);write(txt,string'(" = "));write(txt,sync_out_expected_prev);
write(txt,string'("| real "));write(txt,output_test_name);write(txt,string'(" = "));write(txt,output_test_prev);
write(txt,string'("| real "));write(txt,sync_out_name);write(txt,string'(" = "));write(txt,sync_out_prev);
i := i + 1;
END IF;
IF ( output_test_expected_prev /= 'X' ) AND (output_test_expected_prev /= 'U' ) AND (output_test_prev /= output_test_expected_prev) AND (
(output_test_expected_prev /= last_output_test_exp) OR
(on_first_change(1) = '1')
) THEN
throw_error("output_test",output_test_expected_prev,output_test_prev);
num_mismatches(0) <= num_mismatches(0) + 1;
on_first_change(1) := '0';
last_output_test_exp := output_test_expected_prev;
END IF;
IF ( sync_out_expected_prev /= 'X' ) AND (sync_out_expected_prev /= 'U' ) AND (sync_out_prev /= sync_out_expected_prev) AND (
(sync_out_expected_prev /= last_sync_out_exp) OR
(on_first_change(2) = '1')
) THEN
throw_error("sync_out",sync_out_expected_prev,sync_out_prev);
num_mismatches(1) <= num_mismatches(1) + 1;
on_first_change(2) := '0';
last_sync_out_exp := sync_out_expected_prev;
END IF;
trigger_i <= NOT trigger_i;
END PROCESS t_prcs_selfcheck;
t_prcs_trigger_res : PROCESS(trigger_e,trigger_i,trigger_r)
BEGIN
trigger <= trigger_i XOR trigger_e XOR trigger_r;
END PROCESS t_prcs_trigger_res;
t_prcs_endsim : PROCESS
VARIABLE total_mismatches : INTEGER := 0;
BEGIN
WAIT FOR 1000000 ps;
total_mismatches := num_mismatches(0) + num_mismatches(1);
IF (total_mismatches = 0) THEN
write(txt,string'("Simulation passed !"));
ELSE
write(txt,total_mismatches);
write(txt,string'(" mismatched vectors : Simulation failed !"));
END IF;
WAIT;
END PROCESS t_prcs_endsim;
END ovec_arch;
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
-- Second part of the testbench file --
LIBRARY ieee;
LIBRARY STD;
USE STD.textio.ALL;
ENTITY test_project_vhd_vec_tst IS
END test_project_vhd_vec_tst;
ARCHITECTURE test_project_arch OF test_project_vhd_vec_tst IS
-- constants
-- signals
SIGNAL master_clock : STD_LOGIC;
SIGNAL N : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL output_test : STD_LOGIC;
SIGNAL sync_in : STD_LOGIC;
SIGNAL sync_out : STD_LOGIC;
SIGNAL sampler : sample_type;
COMPONENT test_project
PORT (
output_test : OUT STD_LOGIC;
sync_out : OUT STD_LOGIC
END COMPONENT;
COMPONENT test_project_vhd_check_tst
PORT (
END COMPONENT;
COMPONENT test_project_vhd_sample_tst
PORT (
END COMPONENT;
BEGIN
i1 : test_project
PORT MAP (
-- list connections between master ports and signals
master_clock => master_clock,
N => N,
output_test => output_test,
sync_in => sync_in,
sync_out => sync_out
-- master_clock
t_prcs_master_clock: PROCESS
BEGIN
LOOP
master_clock <= '0';
WAIT FOR 5000 ps;
master_clock <= '1';
WAIT FOR 5000 ps;
IF (NOW >= 1000000 ps) THEN WAIT; END IF;
END LOOP;
END PROCESS t_prcs_master_clock;
-- N
t_prcs_N_31: PROCESS
BEGIN
N(31) <= '0';
WAIT;
END PROCESS t_prcs_N_31;
-- N
t_prcs_N_30: PROCESS
BEGIN
N(30) <= '0';
WAIT;
END PROCESS t_prcs_N_30;
-- N
t_prcs_N_29: PROCESS
BEGIN
N(29) <= '0';
WAIT;
END PROCESS t_prcs_N_29;
-- N
t_prcs_N_28: PROCESS
BEGIN
N(28) <= '0';
WAIT;
END PROCESS t_prcs_N_28;
-- N
t_prcs_N_27: PROCESS
BEGIN
N(27) <= '0';
WAIT;
END PROCESS t_prcs_N_27;
-- N
t_prcs_N_26: PROCESS
BEGIN
N(26) <= '0';
WAIT;
END PROCESS t_prcs_N_26;
-- N
t_prcs_N_25: PROCESS
BEGIN
N(25) <= '0';
WAIT;
END PROCESS t_prcs_N_25;
-- N
t_prcs_N_24: PROCESS
BEGIN
N(24) <= '0';
WAIT;
END PROCESS t_prcs_N_24;
-- N
t_prcs_N_23: PROCESS
BEGIN
N(23) <= '0';
WAIT;
END PROCESS t_prcs_N_23;
-- N
t_prcs_N_22: PROCESS
BEGIN
N(22) <= '0';
WAIT;
END PROCESS t_prcs_N_22;
-- N
t_prcs_N_21: PROCESS
BEGIN
N(21) <= '0';
WAIT;
END PROCESS t_prcs_N_21;
-- N
t_prcs_N_20: PROCESS
BEGIN
N(20) <= '0';
WAIT;
END PROCESS t_prcs_N_20;
-- N
t_prcs_N_19: PROCESS
BEGIN
N(19) <= '0';
WAIT;
END PROCESS t_prcs_N_19;
-- N
t_prcs_N_18: PROCESS
BEGIN
N(18) <= '0';
WAIT;
END PROCESS t_prcs_N_18;
-- N
t_prcs_N_17: PROCESS
BEGIN
N(17) <= '0';
WAIT;
END PROCESS t_prcs_N_17;
-- N
t_prcs_N_16: PROCESS
BEGIN
N(16) <= '0';
WAIT;
END PROCESS t_prcs_N_16;
-- N
t_prcs_N_15: PROCESS
BEGIN
N(15) <= '0';
WAIT;
END PROCESS t_prcs_N_15;
-- N
t_prcs_N_14: PROCESS
BEGIN
N(14) <= '0';
WAIT;
END PROCESS t_prcs_N_14;
-- N
t_prcs_N_13: PROCESS
BEGIN
N(13) <= '0';
WAIT;
END PROCESS t_prcs_N_13;
-- N
t_prcs_N_12: PROCESS
BEGIN
N(12) <= '0';
WAIT;
END PROCESS t_prcs_N_12;
-- N
t_prcs_N_11: PROCESS
BEGIN
N(11) <= '0';
WAIT;
END PROCESS t_prcs_N_11;
-- N
t_prcs_N_10: PROCESS
BEGIN
N(10) <= '0';
WAIT;
END PROCESS t_prcs_N_10;
-- N
t_prcs_N_9: PROCESS
BEGIN
N(9) <= '0';
WAIT;
END PROCESS t_prcs_N_9;
-- N
t_prcs_N_8: PROCESS
BEGIN
N(8) <= '0';
WAIT;
END PROCESS t_prcs_N_8;
-- N
t_prcs_N_7: PROCESS
BEGIN
N(7) <= '0';
WAIT;
END PROCESS t_prcs_N_7;
-- N
t_prcs_N_6: PROCESS
BEGIN
N(6) <= '0';
WAIT;
END PROCESS t_prcs_N_6;
-- N
t_prcs_N_5: PROCESS
BEGIN
N(5) <= '1';
WAIT;
END PROCESS t_prcs_N_5;
-- N
t_prcs_N_4: PROCESS
BEGIN
N(4) <= '1';
WAIT;
END PROCESS t_prcs_N_4;
-- N
t_prcs_N_3: PROCESS
BEGIN
N(3) <= '0';
WAIT;
END PROCESS t_prcs_N_3;
-- N
t_prcs_N_2: PROCESS
BEGIN
N(2) <= '1';
WAIT;
END PROCESS t_prcs_N_2;
-- N
t_prcs_N_1: PROCESS
BEGIN
N(1) <= '0';
WAIT;
END PROCESS t_prcs_N_1;
-- N
t_prcs_N_0: PROCESS
BEGIN
N(0) <= '0';
WAIT;
END PROCESS t_prcs_N_0;
-- sync_in
t_prcs_sync_in: PROCESS
BEGIN
sync_in <= '1';
WAIT FOR 7000 ps;
FOR i IN 1 TO 9
LOOP
sync_in <= '0';
WAIT FOR 50000 ps;
sync_in <= '1';
WAIT FOR 50000 ps;
END LOOP;
sync_in <= '0';
WAIT FOR 50000 ps;
sync_in <= '1';
WAIT;
END PROCESS t_prcs_sync_in;
tb_sample : test_project_vhd_sample_tst
PORT MAP (
N => N,
sync_in => sync_in,
sampler => sampler
tb_out : test_project_vhd_check_tst
PORT MAP (
sync_out => sync_out,
sampler => sampler
END test_project_arch;
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
That stuff at the beginning of the text file is defining a load of procedures that write different types out to a file. Any generated code tends to have a load of stuff that probably be hidden away in a package if you wrote it yourself.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
How did you convert the simulation file from a .wvf file to a testbench HDL file?
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
