21615 Discussions
Is the internal oscillator frequency of MAXV devices always within the specified range of 3.9-5.3 MHz, or can it be the same for multiple chips?
NMars4
When setting up the device in Quartus, it gives you the option to set the internal frequency to either 3.9 or 5.3 MHz. I can't find any info though that says that ALL MAXV devices set to 3.9 MHz will run at 3.9 MHz, or if Intel is just saying "We guarantee it will be within this range". I will be using this in dozens of applications and want to make sure the oscillator is at least consistent in all of them.
KhaiChein_Y_Intel
You have to check the datasheet to make sure that the frequency you set is within the range.
