Programmable Devices
21615 Discussions
Is there any document describing Altera Jtag components?
I find the component **_jtag in the library of Quartus, but cann't find detailed information about it.
The component is as below:
component cyclone_jtag
generic (
lpm_hint : string := "UNUSED";
lpm_type : string := "cyclone_jtag" );
port(
clkdruser : out std_logic;
ntrst : in std_logic := '0';
runidleuser : out std_logic;
shiftuser : out std_logic;
tck : in std_logic := '0';
tckutap : out std_logic;
tdi : in std_logic := '0';
tdiutap : out std_logic;
tdo : out std_logic;
tdouser : in std_logic := '0';
tdoutap : in std_logic := '0';
tms : in std_logic := '0';
tmsutap : out std_logic;
updateuser : out std_logic;
usr1user : out std_logic
end component;
The JTAG components are not well documented.
Here's my notes:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/vjtag.pdf
You'll find that the cyclone_jtag is a device-specific implementation of some other generic JTAG component.
What were you trying to implement?
Cheers,
Dave
Hi, Dave,
I am trying to use these family_jtags to connect our JTAG-supported soft modules(inside FPGAs), so we can access both vendor's JTAG component and our soft modules by software.
Your notes give the information about virtual jtag, but the component "family_jtag" is the primitive. What I really want to use is the primitive.
Is there any detailed information about this component's pinout?
--- Quote Start ---
--- Quote End ---
The *only* supported JTAG component is the SLD_Virtual_JTAG component. Altera's JTAG-to-Avalon components are internally constructed from a component that is essentially identical to this part too, eg., see these notes:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf
I'm still not quite clear on your requirements:
1) If you have a JTAG-like component that you want to access, you need to connect it via the SLD_Virtual_JTAG component.
2) If you have a component with registers, then you can access it via a JTAG-to-Avalon-MM bridge, just provide your component with an Avalon-MM slave interface.
Can you please clarify.
Cheers,
Dave
My application is the first one.
Did you mean users can not use "cyclone_jtag" component in the "..\quartus\libraries\vhdl\cyclone_components.vhd"?
What's this "cyclone_jtag" component for?
Ryan
--- Quote Start ---
--- Quote End ---
Then Altera will only support you if you use the SLD_Virtual_JTAG component.
--- Quote Start ---
--- Quote End ---
It might be used when creating a simulation model.
You might also find that if you use a MegaWizard to instantiate a JTAG component that this component is internally used. However, direct instantiation of the SLD_Virtual_JTAG should give you identical (or at least very similar) control.
Keep in mind that any VHDL you can read in the atoms files or the low-level device files *is not real*, i.e., you will never get to see what Altera synthesis files look like. That is all part of their secret-sauce.
If you are trying to create a vendor-neutral interface to your JTAG components, then you need to go through the SLD_Vitual_JTAG components for Altera, and the BSCAN components for Xilinx, and I forget what the JTAG components are called for Lattice. Bottom line is you have to use a vendor specific component to access your vendor neutral code.
Cheers,
Dave
I see.
Thanks for your advice.
Ryan
--- Quote Start ---
--- Quote End ---
No problem. Hopefully it saved you some time.
If you have a specific use-case that you do not want to discuss here, eg., a code example, just send me an email directly (to my forum name).
Cheers,
Dave
