Hi All,
I have two boards with MAX-10 on each of them. The communication between boards is done using SPI interface. Both boards have JTAG. Is there a way to control the SPI IF using JTAG? Could the internal logic modules inside of MAX-10 be controlled through JTAG IF as well? Thank you!Link Copied
You can use Virtual JTAG or In-System Sources & Probes to provide a JTAG interface to the logic fabric. Review the respective documentation.
