21602 Discussions
JTAG did not work.
Hello all. We are make PCIe board at Aria GX2. It's highly simplified kit from Altera. The DC/DC is working very good. But JTAGs didn't work at all.
I can see signals at JTAG TDI, TMS, TCK but nothing at TDO. I'm try to connect TDI to MAX-II and ArriaGX-II in parallel and disconnect MAX TDO from Arria TDI. But I can't see signals at MAX TDO and Attia TDO.
I'm use 2.5v to supply MAX and Arria JTAG banks.
MSELs connected to ground. nConfig and nStatus I'm pull up.
This is a test.
--- Quote Start ---
This is a test.
--- Quote End ---
You test is ok. Jtag is't ok.
The JTAG tap controller enables TDO, when it's state advances to a SHIFT_DR or SHIFT_IR state. Never reaching this state (respectively not seeing TDO activated) in standard JTAG scan and similar actions most likely indicates:
- device is held in reset, because one of the supply voltages required for JTAG operation (see the manual for details) is below it's reset threshold
- TMS, TCK or TDO are not connected correctly
--- Quote Start ---
--- Quote End ---
Volatges is ok. Core - ok and IO Bank is ok.
--- Quote Start ---
--- Quote End ---
I'm check this many times. It's ok. I'm even solder wire direct from JTAG pin to closed via from Arria chip.
According to the device manual, POR is monitoring these supply voltages:
VCCCB, VCCA_PLL, VCC, VCCPD, and VCCIO for I/O banks 3C or 8C
--- Quote Start ---
--- Quote End ---
All voltages, pll, etc, is ok.
