21604 Discussions
Jtag Working Wrong!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hi everybody!
Recently,I'm debug a board about Ep2c8 which build by myself,after I welding end all devices,
I made a sample test program and download it with QuartusII8.0. Then Quartus tell me download success! But I find that fpga does't work as my test program!My test program just make fpga's some pins output as low! As a result ,all pins output as a high!
So ,Someone who know about it ,please tell me why!!
Thank you very much!
Shenhuan 2009-11-22:confused:
Or who can tell me something may cause this !
The signalTapII does't work too!
What do you mean by "signalTapII does't work"? What's the status of the CONF_DONE pin?
SignalTap can build and download ,but when i run it ,it show me that jtag communication error!
Did you setup the JTAG hardware correctly in Signaltap? Does it find your FPGA?
Yes!QuartusII show me download success!
I meant the JTAG hardware configuration in Signaltap.
What are the levels of the nCONFIG and CONF_DONE pins after configuration?
nCONFIG is high and CONF_DONE is low
CONF_DONE should be high after the FPGA has been programmed. Do you have an external pull-up on the pin?
Yes! Is there something others may cause this?
The only cause I can see is that an error occured during the FPGA configuration, but it's strange that Quartus doesn't detect it.
There could also be a problem with one of the power supplies or a bad decoupling but I'm not sure it would prevent the COND_DONE pin from going high.
Do you have another design that you can test?
Thanks for your advice!
My board work now,there are something about nCS pin,because the problem of welding,nCS pin hasnot been pull down to ground!
