21586 Discussions
Keeping I/O pins to GND during power up
Hello everybody from southern Germany,
I am using a CPLD in a design which drives 4 fullbridge mosfet
drivers , and thus while the system is powering up I need to ensure
that the I/O's which control the drivers remain at GND potentail the entire time while powering up.
I have tried the ISP clamp option which definitely holds the
I/O port low while programming, but the port still goes to VDD
while ramping up power for about 250 uS which the fullbridge cannot
tolerate.
It seems like this may have more to do with the external circuitry to overcome
the weak pullup, any ideas ?
Thanks a bunch,
Eric
A strong pull-down?
Use an isolator (optic or magnetic i.e. ADUM3440) between the FPGA and the mosfet driver.
Only enable the isolator after the FPGA has powered up.
The advantage of the iso is that it protects your FPGA.
