21594 Discussions
LCA10K30 FPGA Alternative
arjunkumarm
Hi
We have an old design with LCA10K30 FPGA,
It is a very old FPGA so technical documents are not available and it is obsolete too.
please suggest me any alternative FPGA for the same.
Farabi
If your design does not need transceiver, you may want to explore MAX10.
link : https://www.intel.com/content/www/us/en/products/details/fpga/max/10.html
regards,
Farabi
arjunkumarm
Which transceiver you are talking about?
Do you have any documents(datasheet) of LCA10K30 FPGA?
Farabi
No I dont have LCA10K30 datasheet. The part number you give also not matching with Intel FPGA part numbers.
I would suggest to use MAX10 as recommended in your future design.
regards,
Farabi
