21603 Discussions
fpga core and fpga transceiver use the same voltage source
lambert_yu
  Now we have one board that its core and transceiver use the same voltage source:
  FPGA TYPE : 10ax115n2f45i2sg
  pre chage this voltage (about 0.9v), use 4 simplex tx transceiver and 4 simplex rx transceiver.
  when we do the transceiver prj, the transceiver could not work normally;
  after chage this voltage (about 1.03v), use 8 simplex tx transceiver and 8 simplex rx transceiver.
  when we do the transceiver prj, the transceiver could work normally;
  I want to know, if we use this supply method for fpga core( exceed its typical voltage from datasheet), will it effect the fpga core logic function? If yes, is there  any suggestion for this voltage level when use this board?
Brs,
Lambert
Kshitij_Intel
As per Intel® Arria® 10 Device Datasheet Recommended Typical Transceiver Power Supply Operating Conditions for transmitter and receiver is 1.03V. For more information please refer to the below link.
https://www.intel.com/content/www/us/en/docs/programmable/683771/current/transceiver-power-supply-operating-.html
Also, please follow the Intel® Arria® 10 Device Family Pin Connection Guidelines.
https://www.intel.com/content/www/us/en/docs/programmable/683814/current/transceiver-pins.html
Thank you
Kshitij Goel
Kshitij_Intel
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you
Kshitij Goel
