21601 討論
Use FPGA to reclock audio I2S/ADAT/SPDIF signals
lelsteph
初學者
2,778 檢視
I am completely new to FPGA / CPLD Any help or guidance will be really appreciate!
I am looking for a way to reclock audio spdif/adat/i2s signal to remove jitter. It seems I can use some Altera FPGA.
I do not want to re-invent the wheel.
Do you know if some application examples, application notes etc... are available?
Thank you very much!
Stephane.
0 積分
5 回應
Ash_R_Intel
員工
2,717 檢視
Can you be more specific in the requirement here? Are you looking for a PLL reference design or any specific protocol?
Ash_R_Intel
員工
2,717 檢視
There are several reference designs available for reference. Please check below links:
FPGA Wiki - Intel Communities
Intel® FPGA SDK for OpenCL Design Examples | Intel
lelsteph
初學者
2,707 檢視
Hello
I am looking for a solution to reclock:
- COAX SPDIF
- OPT SPDIF
- I2S (2 channels)
with extremely low jitter < 100-200fs.
An XMOS is generating above streams.
Plan is to use extremely precise clocks like Crystek or Accusilion 45.1584MHz & 49.152MHz (or multiple).
The "re-clocker" would take the COAX SPDIF and the OPT SPDIF and from above clock will reclock the signals by sending the clock back to the XMOS to get the data bits.
The "reclock" would take the I2S signals: CLK, LRCLK, DATA and reclock using above clocks.
There are tons of such boards on the market using Intel FPGA so I am quite sure this was already implemented. I do not want to re-invent the wheel
Thank you for any help!
Stephane.
Ash_R_Intel
員工
2,641 檢視
As I understand your requirement, I think you are looking for clock switching. Suggest you to please go clocking architecture of whichever device that is targeted. For example, following link talks about MAX 10 clock control block.
https://www.intel.com/content/www/us/en/docs/programmable/683047/21-1/global-clock-control-block.html
Also check the ALTCLKCTRL IP mentioned in the same document.
Ash_R_Intel
員工
2,611 檢視
As there are no further queries, I am setting this case to closure. However, it will still be open for the community members to comment.
回覆
