Hi FOlks,
THis is probably an easy one for someone to explain: In the altlvds_rx moduloe, what does the 'register outputs' actually do/mean??? many thanks DLink Copied
Hi deBoogle,
This is an option to put a barrel register to synchronise parallel data output or not directly inside the IP. If not it's recommended to put one outside the IP. Regards, Romain
