Hi everyone,
I'm sending out from FPGA a lot of signals at LVDS with low data rate.
Is it possible to use both true LVDS transmitter channels and emulated LVDS output channels together as an output LVDS channels?
連結已複製
4 回應
Hi @AGofs Theoretically possible depending on how low is your datarate. However, for the LVDS IP Core, you can give a quick try to assign part of the channels as True and the others as Emulated, and see if the fitter allows it.
