21611 Discussions
LVDS and emulated LVDS outputs
AGofs
Hi everyone,
I'm sending out from FPGA a lot of signals at LVDS with low data rate.
Is it possible to use both true LVDS transmitter channels and emulated LVDS output channels together as an output LVDS channels?
AGofs
Hi everyone,
Do you have something new about this issue?
JonWay_C_Intel
Hi @AGofs​ Theoretically possible depending on how low is your datarate. However, for the LVDS IP Core, you can give a quick try to assign part of the channels as True and the others as Emulated, and see if the fitter allows it.
AGofs
Hi JwChin,
Thank you for your answer!
I'll try to use LVDS_TX IP core to check if it is possible.
But what will happen if resistor terminations (for LVDS emulated channels) will be removed?
JonWay_C_Intel
Let me put this answer in the right place: The RS and RP external resistors is to give an effective 100 ohm differential output impedance
