Programmable Devices
21608 Discussions
LVDS differential input rails flipped
One of the boards that I have received has differential rails flipped i.e. {p,n} are connected as {n,p}. I am wondering if I can still use the board this way and invert the signal inside the fpga? Is there any downside to doing this?
Thank you.
Sanjay
--- Quote Start ---
--- Quote End ---
This is sometimes done to make the PCB routing possible. Inverting the signal inside the FPGA is fine.
Cheers,
Dave
