Programmable Devices
21611 Discussions
License Problem
I have created the encrypted RTL files with the new license but If I replace the earlier license with the new license I am not able to create the SOF(bit) file.
Can anyone let me know how to add two license to the Altera tool.
Vijay K
I don't know if this solution will resolve your problem or no, but try it.
you add under environnement variable two system variable, they have as name : "1-LM_LICENSE_FILE 2-MGLS_LICENSE_FILE" and we write the path of your second license to the above variable.
Good luck
In quartus, you can type both license files in with a ; between them:
IE c:\licenses\license1.dat;c:\licenses\license2.dat
This also works with the environment variables LM_LICENSE_FILE etc.
Pete
