Programmable Devices
21602 Discussions
Lid Removal
Ed6
What is the temperature needed to soften the adhesive between the lid and die of the programmable gate array FPGA 10AX066N2F40I1HG?
Ed6
Yes; we spoke with the SME last night and obtained our answer plus a way to answer future questions through the Premier Service.  Thank you very much for your help!
AndrewG_Intel
Hello Ed6
After checking your inquiry, we noticed it is regarding Intel® Arria 10 GX FPGA - Field Programmable Gate Array (part number 10AX066N2F40I1HG). We have a forum for these specific products and inquiries so we are moving this to the Programmable Devices forum so it can get answered more quickly.
https://community.intel.com/t5/Programmable-Devices/bd-p/programmable-devices
Andrew G.
NurAiman_M_Intel
Thank you for contacting Intel community.
Are you referring to process reflow? If yes, kindly go to the link below for further information:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an353.pdf
Thank you.
Aiman
Ed6
  1. Hi -
  2. No; we are performing a Destructive Physical Analysis (DPA) on these parts as required by the US Department Of Defense.  We are not trying to solder this IC to a board.  We are trying to remove the lid to be able to perform Scanning Acoustic Microscopy on the part.  How would you recommend that we remove the lid from the part without damaging the internal parts?
NurAiman_M_Intel
Thanks for your response.
Per my understanding, you are referring to the reliability report,:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rr/rr.pdf
Aiman
Ed6
Unfortunately, that did not tell me how to remove the lid from the IC without damaging the die and other internal components.  Can you please provide the process we can follow to remove the metal lid from the Integrated Circuit without damaging the die and other internal components.  It appears the metal lid is held on to the die by an epoxy.
NurAiman_M_Intel
I have response to you in forum email.
Thank you.
Aiman
NurAiman_M_Intel
Hi Ed6,
I have emailed you the contact person for further action. Please take a look and let me know once you contacted the person.
Aiman
BD28
Hi Aiman,
who is the contact engineer that has the solution for this issue?
NurAiman_M_Intel
Do you have any update? Have you contacted the person in the email that I have sent you?
Thank you.
Aiman
Ed6
NurAiman_M_Intel
Thank you for your update. I will close this case. In the future, kindly use IPS for further support.
Aiman
