21618 Discussions
Locking period of a Femto crystal to give a stable output frequency
Hi all,
I'm working on PCR, so i'm using a femto crystal to generate 27MHz frequency by controlling the duty cycle passed to the crystal.
I wanted to know how long will it take for the crystal to produce a stable frequency upon supplying a certain duty cycle.
The crystal is a Femto clock VCXO ICS810001-21.
Thank you,
I think that's a question for IDT. However, they're immediately going to ask you how much of a step you're intending to put on it from which it needs to settle.
A quick scan of the datasheet didn't reveal anything obvious...
You might consider the 'Lock time' stated. I appreciate this is from power up, but if you can design for a fraction of such a delay then I think you'll be on the right lines.
Cheers,
Alex
