21615 Discussions
Logic error? Code error?
Hello people,
So this is my problem. I am designing a module which is basically reading from a device. Now, depending on the inputs to this module, it access different parts of the device.
if rtc_state = s0 then if hmi_en = '1' then if hmi_rdwr = '1' then rtc_state <= sHMI_rd; buff_hmi_addr <= hmi_addr; else rtc_state <= sHMI_wr; buff_hmi_addr <= hmi_addr; buff_hmi_data <= hmi_data; end if; elsif rd_wr = '0' then rtc_state <= sWr; buff_addr <= addr; buff_data <= data; flag_wr <= '1'; elsif rd_wr = '1' and SQW = '1' and U_EN = '1' then rtc_state <= s1; else rtc_state <= s0; end if; end if;
Well, i've narrowed down the problem to this piece of code. Actually, i get a warning that signals dependent on the signal hmi_en are stuck to ground. Also, if i change the statement if hmi_en = '1' then to if hmi_en = '0' then then all the other states become redundant because the damn thing seems to be stuck to GND.
Note: hmi_en is an input which is coming from port.
Any/All help is appreciated.
Thanks & Regards,
Yash
The code itself seems ok but...
First: the signal hmi_en seems stuck to '0' and is never '1'.
Second:You are not following a standard state machine template, assuming you are doing a state machine.
Kaz
--- Quote Start ---
Hello people,
Thanks & Regards,
Yash
--- Quote End ---
Hi ,
maybe it is a stupid question, but do check that the signal hmi_en is really connected to the port ? No type mismatch ? Be aware that Verilog is case sensitive.
