c2h problem!
My nios ii version is 8.0,and i used c2h in it ,the function is
unsigned short add(unsigned short a,unsigned short b){
unsigned short sum=0;
sum=a+b;
return sum;
and main function is
int main()
unsigned short s1=10,s2=10;
unsigned s;
//printf("Hello from Nios II!\n");
s=add(s1,s2);
printf("the sum is %ld\n",(long)s);
return 0;
the result is the sum is 1
why?why did i get wrong result with c2h?
My nios is the crack,so i download the limited sof to board
