Programmable Devices
21595 Discussions
Lost Quartus II project
hi
i am a university student, made servo control board using MAX 3000 device now i have lost my quartus II project (Student Version) because of my harddisk failure now i have only one programmed EPM3128ATC100 device , may i recover my project filed from this device.
--- Quote Start ---
hi
--- Quote End ---
I don't for sure, but if your lucky you can read back the programming of the device.
You will not be able to recover your complete project.
Unfortunately you will be able only to recover a binary programming file but not the source code.
can you please help me to recover binary of program
--- Quote Start ---
--- Quote End ---
Connect the programmer to your board -> choose Examine
This loads the programming dataint oa temporary file.
Then choose "Save file"
thanks dear
but there is no option in quartus II v8 programmer for examine
pradeep
--- Quote Start ---
thanks dear
pradeep
--- Quote End ---
When you has opened the programmer click on "Add device" and choose your device.
After that the examine option will be available.
i think may be this will happen in MAX+PLUSII programmer!
is this binary can be used to program another device
--- Quote Start ---
--- Quote End ---
Sorry, I was not aware that you are using Max+PlusII, nevertheless it should also work.
no i am using QUARTUS II version 8
--- Quote Start ---
--- Quote End ---
What kind of HW do you us for programming ? ( USB-Blaster ???)
I have a picture attached, were you can see how to switch on the examine feature.
i am using 3rd party BYTE BLASTER hardware for programming
regarding this examine feature in my QUARTUSII programmer i am unable to check on examine CheckBox
--- Quote Start ---
--- Quote End ---
which programming mode are using ? Did you use a Altera Web edition ?
yes its an altera web edition
--- Quote Start ---
--- Quote End ---
Did you use the "JTAG" programming mode ? Unfortunately I have not the Quartus 8.0 Web edition available, but in the 8.1 Version I'm able to switch the examine feature on.
