21602 Discussions
MAX 10 10M02SCU169C8G The output port doesn't initialize as I programmed
Hi Guys,
I am new in this field so I don't have much experience. I assigned my output port to 0 like this:
module acm_top
....output bmc_csa_l,
output bmc_csb_l,
assign bmc_csa_l = 1'b0;
assign bmc_csb_l = 1'b1;
The synthesized circuit acted right after I programmed the chip but the next time I powered up the circuit, it set bmc_csa_l tohigh which is not acting as my code.
I did try to assign this port to a register and reset it but my circuit lacks the reset input and it still not worked
module acm_top
output bmc_csb_l,
reg [1:0] rbmccs;
assign bmc_csa_l = rbmccs[0];assign bmc_csb_l = rbmccs[1];
always @ ( posedge core_clk or posedge rst )
begin
rbmccs[0] <= 1'b0;
rbmccs[1] <= 1'b1;
end
It's not just this two pins didn't work, some other pins as well. Did anyone experience same issue? Please help me solve this problem, thanks!
You can check the FPGA's configuraion pins nStatus, Config_Done value to check the mode of FPGA is user mode or not.
--- Quote Start ---
--- Quote End ---
It turned out I programmed the wrong image. I supposed to programmed .pof file but I programmed .sof file.
Stupid me. Thanks for the reply though.
