21600 Discussions
MAX 10 CPLD FW update question
Matthew99
Hi all,
For MAX 10 CPLD FW update, in addition to use Embedded USB-Blaster II (JTAG) to update CPLD FW.
is there any other way to program CPLD FW?
After installing Quartus Prime software, is there any program I can use to update CPLD FW?
any suggestion?
FvM
by using remote update IP, you can update MAX10 flash through any interface of your choice, e.g. UART, SPI, I2C or custom designed.
JTAG update can also use third party JTAG interfaces.
Matthew99
Hi @FvM
Thanks for your kind reply.
Could you explain it in detail about remote update IP? any link or document?
is there any Quartus Prime program I can use to program CPLD fw?
the program should be running on ARM (within BMC system)
any suggestions?
FvM
best interface should be chosen according to existing connections between uC and FPGA. If you already have a communication interface, it can be used for flash update  too. Intel® MAX® 10 FPGA Configuration User Guide is describing remote update requirements, including links to reference designs.
There's also embedded JTAG driver code available ("jrunner"), but I'm not sure if can be used to write non-volatile MAX 10 configurations.
WZ2
