Programmable Devices
21570 Discussions
MAX 10 CRC_ERROR PIN
Idanga
Is it possible to use the CRC_ERROR pin as a regularuser input?
Assuming I have defined the following:
FvM
Hi
MAX10 pinout file answers your question. CRC_ERROR is optional function of IO pin.
If you choose a pin assignment that's not feasible, Quartus will tell you when trying to compile the design. I suggest to always perform a test compile before finishing a PCB design.
NurAiman_M_Intel
FvM answer is acceptable. You may refer to the MAX10 pinout file.
Aiman
NurAiman_M_Intel
  • As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘ https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
