21607 Discussions
MAX 10 Modular ADC TSD
Hey,
I followed instruction from the example project on this page: https://cloud.altera.com/devstore/platform/16.0.0/nios-ii-on-die-temperature-sensor-design-example/
trying to read on-die temperature.
Whatever settings I try to change (including the original) I keeps reading only slot# 1 out of the 64 of the example, all the others are zeros.
Even that first one gives me irrational -15/16/17 Celsius degrees (code 3754/6/9).
I'm using model 10M50DAF256I7G.
I found vary little on this on the web.
EDIT 1:
So the example project does work on the development kit (gives reasonable temperature), with model 10M50DAF484C6GES.
The question remains why model 10M50DAF256I7G returns unreasonable temperature.
EDIT 2:
I tried with another board with 10M50DAF256I7G and it returns even weirder values at around 3800's code.
EDIT 3:
With the ADC toolkit I can see changes that makes sense, for example when I try to change the temperature by touching it, and it happens in both models, and with all three boards.
So I suspect different models return different codes, although it I can't find any references about it and it certainly doesn't say it in the MAX 10 ADC datasheet. Anyone here have a stand about it?
Eyar
Hi Eyar,
I expirience the same behaviour although on different models. Gives reasonable readings on 10M50DAF484C6GES (development kit), but offset on 10M04,10M08 based boards same Qsys design.
