21602 Discussions
MAX 10 using on chip flash with Nios II
AWals
I am trying to use the alt_write_flash function to program data to the UFM on a MAX 10 device. The program code for the Nios II is executing in place from the UFM space (boot option 1b) but i would like to write to unused UFM from the program code. Is this allowed by the onchip flash controller? When i use the alt_write_flash function in the Nios II code it just hangs indefinitely.
AWals
Now I am getting a timeout during the UFM write. I am also experiencing pretty flaky behavior when writing to UFM. When I compile the design I get the following timing warning in the quartus messages.
Warning (332056): PLL cross checking found inconsistent PLL clock settings:
Warning (332056): Node: u0|onchip_flash_0|altera_onchip_flash_block|ufm_block|osc was found missing 1 generated clock that corresponds to a base clock with a period of: 181.818
Ahmed_H_Intel1
Hi Alan,
It seems that the PLL setting is not correct. Can you please check the PLL?
This maybe the main reason why the flash isn't responding.
