21602 Discussions
MAX10 10M50SCE144C8G trouble on programming
part 10M50SCE144C8G on custom board
first time got programmed, it was working with an issue, corrected the core never load again on device.
Quartus Lite 15.1
Quartus Lite 16.1 won't compile and say pin 26 too close to pin 27 clock issue.
Compiled design on 15.1 16.1 programmer perform same way don't program.
tested all work around found here and on site, no success.
Device is forever detected regardless of Jtagen and confign signal level.
Erase is executed, I clearly see first working Image was erased.
Program as SOF say it 100 % (Succesful) but doesn't seem work.
Program as POF say failure at 0%
verify, blank check say failure at 0%
examine take a long time with progressing bar incrementing 1% every second/ two or more then say 100 % (Succesful) Examine what?
Checked all workaround i seen but none is working, I feel this device as not mature, also software is not so reliable, 15.0 look better but has limited support.
I also don't like incompatible pinout migration on same casing for 02 04-25 the another different pinout for 40 50.
Now this completely stuck me at final step blocking production.
Design was fine on bga484 and all was tested on bemicro max and deca.
Checked Config done, NConfig, but program of pof report failure forever.
Someone has idea why cannot reprogram device?
Programming console on next
Best regards
Roberto
Console output:
Examine:
Info (209060): Started Programmer operation at Sun Feb 5 22:54:28 2017
Info (209017): Device 1 contains JTAG ID code 0x031850DD
Info (209038): Examining devices
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Sun Feb 5 23:00:56 2017
program configure POF
Info (209060): Started Programmer operation at Sun Feb 5 23:02:39 2017
Info (209060): Started Programmer operation at Sun Feb 5 23:02:40 2017
Info (209016): Configuring device index 1
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Sun Feb 5 23:02:41 2017
ERASE
Info (209060): Started Programmer operation at Sun Feb 5 23:06:06 2017
Info (209044): Erasing MAX 10 configuration device(s)
Info (209061): Ended Programmer operation at Sun Feb 5 23:06:06 2017
Program SOF
NConfig High:
NConfig Low:
Info (209060): Started Programmer operation at Sun Feb 5 23:10:54 2017
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209061): Ended Programmer operation at Sun Feb 5 23:11:03 2017
Info (209060): Started Programmer operation at Sun Feb 5 23:12:01 2017
Info (209061): Ended Programmer operation at Sun Feb 5 23:12:10 2017
program pof
Info (209060): Started Programmer operation at Sun Feb 5 23:13:31 2017
Info (209061): Ended Programmer operation at Sun Feb 5 23:13:39 2017
I did not understand "first time got programmed, it was working with an issue, corrected the core never load again on device." What was the issue?
Did you check the power supplies?
--- Quote Start ---
--- Quote End ---
On IP core one signal was at default, iIPCORE display on an LCD two different windows. Due to this error on LCD an image was present where it was expected to be blank, after correcting design was never possible to load again an image to device.
About power supply, I can test it, LCD is lit on, on previous an image was present, after erase was no more possible load core so no image is on display.
I see report from console got lost, so I post again a new one.
Console output:
Erase
Jtagen High
Info (209060): Started Programmer operation at Mon Feb 6 23:35:46 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:35:46 2017
low
Info (209060): Started Programmer operation at Mon Feb 6 23:36:14 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:36:15 2017
Program SOF
Jtagen High/Low
Info (209060): Started Programmer operation at Mon Feb 6 23:37:14 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:37:23 2017
Info (209060): Started Programmer operation at Mon Feb 6 23:37:54 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:38:02 2017
Blank check
Jtagen High
Info (209060): Started Programmer operation at Mon Feb 6 23:38:47 2017
Info (209060): Started Programmer operation at Mon Feb 6 23:38:48 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:38:57 2017
Jtagen Low
Info (209060): Started Programmer operation at Mon Feb 6 23:40:20 2017
Info (209060): Started Programmer operation at Mon Feb 6 23:40:21 2017
Error (209014): CONF_DONE pin failed to go high in device 1. Make sure all communication cables are securely connected, select a different device, check the power on the target system, or make sure all nCE pins are connected to GND. The Altera Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Info (209061): Ended Programmer operation at Mon Feb 6 23:40:29 2017
Info (209060): Started Programmer operation at Mon Feb 6 23:40:57 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:41:06 2017
Examine
JTAG low
Info (209060): Started Programmer operation at Mon Feb 6 23:41:50 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:48:15 2017
program POF
JTAGEN low nCONFIG HIGH
Info (209060): Started Programmer operation at Mon Feb 6 23:50:13 2017
Info (209060): Started Programmer operation at Mon Feb 6 23:50:14 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:50:23 2017
Nconfig Low
Info (209060): Started Programmer operation at Mon Feb 6 23:50:53 2017
Info (209060): Started Programmer operation at Mon Feb 6 23:50:54 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:51:02 2017
Info (209060): Started Programmer operation at Mon Feb 6 23:52:01 2017
Info (209060): Started Programmer operation at Mon Feb 6 23:52:02 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:52:10 2017
second attempt erase program
Info (209060): Started Programmer operation at Mon Feb 6 23:52:40 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:52:40 2017
Info (209060): Started Programmer operation at Mon Feb 6 23:52:47 2017
Info (209061): Ended Programmer operation at Mon Feb 6 23:52:56 2017
--- Quote Start ---
--- Quote End ---
Hi sherif123, you asked me to check the power supply, is this general request or you experienced something on PSU behaviour?
PSU is on board, can deliver 2A@3.3V 3A peak, it feed just MAX10, a 50MHz oscillator, 3 i2C expander, power LED and an SRAM, board is 4 layer with solid ground and power plane under ETQFP, an additional ground plane is under case to help raise down impedance and also transfer away heat.
Some more idea about?
Thank
Hi rommano,
I have a similiar case with M16SAE144C8G with custom board.
As you explained the device can be detected always.
Examine take a long time with progressing bar incrementing 1% every second/ two or more then say 100 % (Succesful)
Did you find any solution for this issue?
Hi rromano001,
Perhaps, you can try to use the latest Quartus stand alone programmer v17.0. You don’t need to install the full Quartus v17.0 version. You only need to install the stand alone programmer. Then you can try to erase the MAX 10 CFM/UFM block and reprogram your .pof file.
https://dl.altera.com/17.0/?edition=standard&platform=windows&download_manager=dlm3&product=qprogrammer#tabs-4
Since you are using E144 package device, make sure the exposed pad on the MAX10 E144 package connected to the ground plane on your board.
nyusof
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Hi rommano,
Yes, I solved this issue, I was using all pin of MAX10, pin 38 config Done was assigned to interrupt of PCA9535EC and PCA8574 I2C expander, one of this when powered up was driving IRQ line low. Also board was unresponsive, removing offending pin from Config Done got again High releasing my board from trouble.
As rule check all status pin are free and can be pulled up, Nstatus and Config done in particular but also some other can be the solution to problem.
Telll me about your progress too.
Actually I still experience trouble with compiler and some strange behaviour with a very simple SRAM controller.
New Quartus after release 15 abort compilation of design when pin near clock input not at ground. I cannot use new quartus and this is a bigger issue, I commissioned a new board but pin are not enough, release 15 output was ok and no jitter issue was noticed, the two pin are low speed and appear as not disturbing ...
Quartus Linux version also seems to lose performance after release 15, about 20 year ago I migrated away from a competitor due to switch from unix to M$, I DON'T wish at all have again to deal with M$ based product.
Best regards.
Roberto
Hi Nyusof, I downloaded release 17.0 and may be i get 17.1 too but when hardware lock is active I fear newest version fail too.
As I wrote issue came from Config done, first .pof got these pin disabled but I learned this:
If config done and or nStatus get stucked low at startup MAX remain in config mode and never got user mode so never load image nor permit program nothing.
I checked about soldering but it was working at first glance, never after rework got working again, both chip got soldered first time on reflow oven second time on IR rework with preheating seat so as I noted when I discovered the cure nothing on hardware was broken. I also think first chip was ok,
After learning also pinout was not portable across all series I modified the layouts and discarded the 40 and 50 version in favour of 25, this is enough for ip core test, final core can be on 04 or 08, I am afraud also 02 can be used but again is not pinout compatible.
I hope in future some new release can be pinout portable from 02 to hi ghest LE.
Next week I plan to install new version, I try again to lock device and see if succeed or not on programming.
Best regards
Roberto
