21602 Discussions
MAX10 Discrete I2C implementation of RSU issue
Greetings,
I'm using Quartus 16.1 and trying to implement remote system upgrade over I2C using a discrete implementation on a MAX 10 (10M08SAE144C8G). After viewing the training videos it is clear that there is a requirement to use dual compressed image in QSYS. When this is done and the design is compiled, the error "14740 Configuration mode on atom ...|ufm_block does not match the project setting" is produced. If I change the QSYS setting to single uncompressed image the compilation completes without error. I don't know if the design works with this setting yet but it seems inconsistent. Am I missing some setting in the Quartus project that must be set to use dual configuration?
Any suggestions for resolving this issue would be much appreciated.
Well now that I'm wiping egg off my face, I found the proper setting in Quartus under the device options button. Sorry for clogging up the forum with this simple issue.
Falkster
Would you be willing to share your discrete RSU design?
