21610 Discussions
MAX10 IO Buffer output impedance
I was just wondering whether anyone have idea regarding typical value of MAX10 GPIO's output impedance.
Thanks in advance.
Best
-Taufiq
Best answer is 'it depends'. What I/O type are you using? Do you enable the OCT (on chip termination) or not? There is not a simple answer to that question.
--- Quote Start ---
--- Quote End ---
I am using 3.0V LVCMOS with max current output and fastest slew rate. No, I don't enable OCT.
Thanks ak6dn btw for replying.
-Taufiq
--- Quote Start ---
-Taufiq
--- Quote End ---
Well, in the Max10 datasheet I/O electrical specs (have you read that?) 3.3V LVCMOS is rated at Vol of 0.2V at Iol of 2mA; this is 100ohm worst case, typical will be lower.
3.0V LVCMOS has a (wierd? questionable?) spec of Vol of 0.2V at Iol of 0.1mA (is this real or a typo?). If real this would be 2000ohm worst case, typical will be lower.
Output impedance can be best derived from I/V slope in output characteristics defined in IBIS files. I see a range of about 6 ohms with 16 mA drive strength up to 30 ohms with 4 mA drive strength for LVCMOS30 typical curves.
