I am planning to use a 10M04SFE144C7G MAX10 FPGA in a design and cannot locate the pinout information. I went to this link:
https://www.altera.com/support/literature/lit-dp.html#max--10 and find the pinout files for SA and SC devices but not the SF devices. Where can I find the SF pinout for the E144 device above? ThanksLink Copied
Does the 10M04SFE144 package exist? I didn't see the ordering code in Quartus II/Prime software, MAX 10 device overview, or MAX 10 Package Specifications.
--- Quote Start --- I am planning to use a 10M04SFE144C7G MAX10 FPGA in a design and cannot locate the pinout information. I went to this link: https://www.altera.com/support/literature/lit-dp.html#max--10 and find the pinout files for SA and SC devices but not the SF devices. Where can I find the SF pinout for the E144 device above? Thanks --- Quote End --- Mind share where did you locate the 10M04SFE144C7G info? ie web link, documentation?
--- Quote Start --- I am planning to use a 10M04SFE144C7G MAX10 FPGA in a design and cannot locate the pinout information. I went to this link: https://www.altera.com/support/literature/lit-dp.html#max--10 and find the pinout files for SA and SC devices but not the SF devices. Where can I find the SF pinout for the E144 device above? Thanks --- Quote End --- Hey atestani, Maybe you can file a Service Request to Altera and request the information from them?
above one is right. it is better to get clarication from Altera directly.
Topic Options
