21594 Discussions
MAX10 RSU upgrade stuck at 100% uploading status
SAB4887
When i try to send upgrade file through serial terminal   uploading process stuck at 100% status & then doesn't do anything.
Any idea why this happening ?
SAB4887
Thanks for reply.
I made it work.
Initially i was using compiled files from provided in Example folder, with that i was getting this issue.
But after compiling(NIOS program) my self  in my system then it worked.
Thanks for checking.
YuanLi_S_Intel
Hi, may i know is this happening all the time? or just random? Also, may i know what device part number you are using with this design example?
SAB4887
Thanks for reply.
I made it work.
