Programmable Devices
21615 Discussions
MAX10 UART RSU - RemoteTerminal.exe DOES NOT WORK
EP1
I have been reading the posts and I'm in a similar situation to the following post:
MAX10 UART RSU EXAMPLE NOT WORKING - Intel Community
There is no way I can see any information on the RemoteTerminal when trying to Perform the Remote System Upgrade with knight_rider.rpd.
Im following the REMOTE SYSTEM UPGRADE LAB (MAX 10 DEVELOPMENT KIT BOARD) and using the MAX10 dev kit.
Has been any updates on resolved this issue since was not resolved on the post linked earlier?
Thanks a lot.
EP1
The steps followed are:
1. Program the FPGA with pfl.sof (successfully)
2. Program the Nios II firmware into QSPI Flash (this is NOT successful).
As a conclusion, the QSPI Flash doesn't get programmed and the RemoteTerminal does not execute the code from remote_update.c
Can anybody provide a correct nios_firmware.pof?
Also, the file softwarearchive.zip is missing from the RSU project. It is needed to manually create nios_firmware.pof
EP1
Picture from the previous fail when programming QSPI Flash
EBERLAZARE_I_Intel
Just a quick check, is both .pof and .hex are generated from the same design?
EBERLAZARE_I_Intel
Any update?
EP1
They both come from the package provided by Intel, so I would assume so.
MAX 10 - MAX10 Remote System Upgrade (RSU) over UART for Nios II Processor (intel.com)
One the project is compiled, the files pfl.sof and Nios_application.pof are saved within the folder "master_image".
They are both ready to use as don't require compilation.
Eli
EBERLAZARE_I_Intel
I will check from my side, have you done any RSU example before? Have you check your MSEL pins for configuration?
EBERLAZARE_I_Intel
Could you try generating your own .pof and try to program your own .pof?
You could try to use the app1's .sopcinfo, build it to get the generated .hex to build the .pof as per the document. Then try to use that.
EBERLAZARE_I_Intel
Any update from your side?
EP1
Have generated all on my own and it works now.
EBERLAZARE_I_Intel
Thanks for your update, if you need help with other issue you may file a new thread.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
