21615 Discussions
MAX10 UART RSU EXAMPLE NOT WORKING
SAB4887
Hello ,
I have MAX10 development kit. I am trying to play with MAX10 RSU with  UART NIOS example files according to AN741 document.
I am able to program all files correctly but when i connect UART to terminal i don't see any  compunction there.
Any idea what i am missing ???
SAB4887
Ash_R_Intel
SAB4887
Yes. I am following AN741.
And I am directly programming MAX10 with files provided by Intel.
Do i need to setup anything specifically if i use those output files ?
Ash_R_Intel
Please check your connection to the board UART port. Are you able to use the Remote Terminal.exe?
SAB4887
I checked UART connection it working  fine.
Yes, i am able to use Remote Terminal.exe but i  am not seeing any data on it?
I tried on two development board both behaves same..
Ash_R_Intel
Can you please tell the steps that you followed in detail?
Ash_R_Intel
Any comment? Waiting for your reply.
SAB4887
Following steps i am following to test "UART Remote upgrade"
Step 1 :  Programmed board with  "pfl.sof" file
Step2 :  Programmed QSPI with ".Hex" file
Step 3 :  Programmed FPGA with "factory_application1.pof"
Step 4 :  the CONFIG_SEL pin on the board is set to 0
Step 5 : UART communication : FPAGA connected through J11 UART connector
Step 6 : Open "Remote terminal.exe" file & configured UART communication.
Step 7: Press the nCONFIG button on the development kit or key-in 1 in the Send text box,then hit
Enter.
But after step7 I don't see any data on Terminal window.. ????
Am I missing anything ????
Ash_R_Intel
Please check if the USB port is getting identified on your machine through Device Manager, when you plug in the connector to on-board UART and connect to your PC. If not, please install the driver.
SAB4887
 Yes, it is being identified as COM Port 9 when i connect to USB to J11 connector.
hareesh
Hi Subodh Bansode,
Are you still facing this issue?
SAB4887
Yes.
hareesh
i am giving video link of Remote System Upgrade in Intel® MAX® 10 Devices. pls follow step by step. if you are facing issue after that let me know.
https://www.youtube.com/watch?v=KPWOpYQD_JM
Thank you,
braind1
This is a private video. Can you make it public?
SAB4887
I did follow that video but still i am seeing same result.
SAB4887
Did i miss any, above explain steps i am following ?
hareesh
I am sharing example project. once again try it same steps with this project files.
https://www.intel.com/content/www/us/en/design-example/714833/max-10-max10-remote-system-upgrade-rsu-over-uart-for-nios-ii-processor.html
hareesh
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
SAB4887
Sorry for late reply.
I did try that example project from above link. But still i am seeing same issue.
EP1
I am having the same problem.
Any new information about how to solve it?
