21604 Discussions
MAX10: combining analog and digital I/O in same bank possible?
MS
testing with MAX10 (having internal ADCs available), I tried to combine in a given I/O bank analog input pins and (almost) static digital I/Os. Quartus currently prevents me from doing that and throws an error message. Obviously I took care to select a unused analog-capable pin for the digital I/O.
Do I do something wrong or is it really not possible to combine analog and digital I/O in the same bank?
Best wishes,
MS
LZhan65
when you say analog, you mean some signals like lvds?
to receive analog signals, because you need to maintain the signal quality (linearity, for example), you need analog transceivers in fpga, so you have to use the high speed transceiver banks.
MS
HI,
"analog" here means "ADC input signal". There's nothing high speed about that signal.
Best wishes,
MS
MS
The answer is documented in the MAX10 ADC User Guide UG-M10ADC (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_adc.pdf) in section 2.1.3: If you use bank 1A for ADC, you cannot use the bank for GPIO.
Best wishes,
MS
JonWay_C_Intel
Hi @MS, it seems you have found the answer to your question. Is there anything else we can help?
MS
Hi JwChin,
Right now I don't need any help any more. The question is answered. Thank you!
Best wishes,
MS
