21598 Discussions
MAX10 dual bitstream in Flash without NIOS
GD76
Not sure if this is right place to ask. For MAX10, I am looking for an app note/reference design to understand how to have dual boot feature. The Flash or QSPI flash stores dual configuration - a backup and primary copy. Both to be programmed in the flash and future field upgrade are done only to primary copy. The factory bitstream is there as golden image but the board will always powerup with primary bitstream. Only during remote or field upgrade, the factory bitstream runs to manage the programming the primary copy location in flash. There is no NIOS  in the design either. Looking to understand how to download two bitstream to MAX10 without NIOS.
NurAiman_M_Intel
Thank you for contacting Intel community.
Kindly refer to Intel MAX 10 configuration userguide for Dual boot (dual configuration IP core):
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf (page 62)
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
